Best converter for me? size? I am doing a th350 swap with my m6 and not sure what size and brand stall i should run. my specs r n my sig. and i will post my dyno graph. i will also be spraying at least a 150 shot.. [IMG]https://www.fquick.com/images/vehicl...8927247739.jpg[/IMG] |
i know someone has a answer..... |
3800-4000 should be a nice comprimise with either motor or spray. I'm giving a 5000 a try and probly have it tightened up but being as I already have it I figure why not try something a little on the extreme. |
god that is big..you think that is a good size for the street. |
I would think you will want a 3800-4000. I'm running a TR224-112 with a 3400 and will be getting it re-stalled to ~ 4000 at the end of the year. |
I would run an SST series 9" set at 4600.This is a proven converetr with your combo.Chevpower runs one very similar in an F-Body. Give me a call or pm Greg 1-866-726-8358 |
so around a high 3s or low 4000 range |
i would say personally a 3800 if your going to spray, i dont know too much but i know my 3600 with a cam bigger than yours is much too small to get into the power band, but my car is NA |
listen to fti! gibe fti or circle d a call! you need a 4500 for your setup man! |
dont you guys think 4500 is way too high for a car that makes peak power @ 5800? |
we run converters like this combo all the time. The SST series converter is designed to get you a high enough stall but with excellent efficiency. As long as we are 1200 away we are good. Greg |
Give us a call and we would like to discuss your needs Mike or Dave at 775 826 9955 |
Mind you, most of these recommendations are for strip only. Without saying what you plan with your car, we can only guess. Also what tires and gears do you have? You may want to only do highway rolls with it and dialy drive it, or you may be looking for only outstanding 60'. I would recommend a converter between a 3500 (nitrous use) up to a 4500 (Max ET effort for the street), on a 2.0 (hooking on street tires, efficient up top) up to a 2.4 (wheels stands on slicks, or good street manners). Talk to the converter manufacturers as they will be the best to suggest a proper converter, not forum users (who mainly have had one coneverter experience). :) |
Originally Posted by 12secSS
(Post 11382854)
Mind you, most of these recommendations are for strip only. Without saying what you plan with your car, we can only guess. Also what tires and gears do you have? You may want to only do highway rolls with it and dialy drive it, or you may be looking for only outstanding 60'. I would recommend a converter between a 3500 (nitrous use) up to a 4500 (Max ET effort for the street), on a 2.0 (hooking on street tires, efficient up top) up to a 2.4 (wheels stands on slicks, or good street manners). Talk to the converter manufacturers as they will be the best to suggest a proper converter, not forum users (who mainly have had one coneverter experience). :) Chris |
(Post 11382854)
Also, a lot of guys are going off what they have in their 4L60E... not a TH350. I agree with FTI and would say around 4500. I DD my 4k stall in my 4L60E. I'm going with a TH400 and will be around 4500ish stall |
© 2024 MH Sub I, LLC dba Internet Brands
