| Hugger | Jun 21, 2009 10:13 PM | Won't move with shifter in OD After a hard launch at the track this evening the car won't move with the shifter in OD. I can pull it down into 1st and it moves like normal. Reverse also works just fine. I haven't tried any other gears besides 1st and reverse. I didn't want to try anything else because it appears that I blew the posi also. Kind of a rough day!
Anyone have any idea what could be wrong? Could this be a pump issue? The trans is a stock 4L60E with a TCI 4000 stall and vacuum modulation installed. What should I check first?
Josh |
