LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Automatic Transmission (https://ls1tech.com/forums/automatic-transmission-13/)
-   -   Trans won't shift after install (https://ls1tech.com/forums/automatic-transmission/1146099-trans-wont-shift-after-install.html)
2000SS1979 Jul 10, 2009 06:58 PM
Installed a new 4l60 and it won't shift now and the speedo does not work. Goes into first and reverse fine but shift any higher. WhAt do you guys think could be the problem?
performabuilt2 Jul 10, 2009 07:26 PM
speedometer not working
2000SS1979 Jul 10, 2009 08:52 PM
Speedometer is not working. I double checked the fluids and they are at the proper levels.
Circle-D Jul 10, 2009 09:53 PM
Performabuilt is saying the reason it won't shift is because the speedometer is not working. The computer does not see movement, so it won't command a shift.
Chris
PedaltoMetal Jul 10, 2009 09:59 PM
Yep what they said. Make sure you pluged the sensor harness in and go from there.
performabuilt2 Jul 11, 2009 05:22 AM
sorry lol I was answering the question lol maybe i should have been more specific
2000SS1979 Jul 11, 2009 07:51 AM
Thanks for the help guys.I knew it was something simple.
© 2026 MH Sub I, LLC dba Internet Brands
