Dyno Results A4 Locked versus Unlocked
I was wondering what the hp/tq differences show on a dyno tune with the torque convertor locked up versus unlocked in 3rd gear? What benefit other than higher numbers would this matter as you 1/4 mile it unlocked. Thanks in advance for any info!!
LS1Tech Co-Founder
I have done this a few times...
350rwhp u/l
375rwhp l
-with heads, cam, LS6 intake, circa 2000.
-locking up 'verter at the track in the middle of 3rd was worth 2mph for me with when I had the PI3600 stall, but after I got a Yank TP4500 the effiiciency of the converter was much higher
-These are OLD OLD numbers, I would have been more like 374rwhp u/l and 400rwhp l'd these days with the cam I had. I had 222/224//113 + GTP heads.
-I initially went 11.75@112 but after tweaking and playing with the combo I went 11.5@116mph, takes time to play with tuning, shiftpoints etc. to dial in a combo.
350rwhp u/l
375rwhp l
With a stock converter you'll see about 6 RWHP difference between locked and unlocked.
Like John stated, with an inefficient converter you can gain some descent 1/4 mile MPH by locking the converter at the proper time.
You lock the coverter on the dyno for tuning. Why? Because with a high stall the following happens:
1) Your rpm readings become skewed and unreliable
2) The shift extension of the converter prevents you from tuning your midrange. For example, let's look at a 4000 stall car being dynoed. A 4000 stall will hold at least 5000 rpm from a punch which is what you do on a dyno. Thus you can not measure your A/F or tune from 3500 - 5000 rpm. Yet, you leave the the line at 4000 rpm so having the maximum possible torque at 3900 - 4400 is absolutely critical to your 60' time.
BTW, your dyno reading may show readings for the lower rpms, but that is part of the problem embedded in issue #1.
I have a Vig 3200 which spiked all the way to 4k on the dyno unlocked and the hp/tq was quite a bit lower than another dyno session. Thats the reason I was asking. Thanks for all the info!!
How do u guys make these assumptions?
First off I have many many friends that run IHRA Top Sportsman cars that run a lockup glide.
Now they gain MPH by using this type of converter/trans in these cars.Point being just because u gain MPH from a lockup switch doesnt mean u have a inefficient converter?
U cant just make a blanket statement that if u need a LU swicth the converter is not efficient.
"How do u guys make these assumptions?"
Joel, please point out where someone in this thread made an assumption.
"U cant just make a blanket statement that if u need a LU swicth the converter is not efficient."
Although I might agree that gaining a good deal of MPH by locking the converter in a 4L60E is an indication of an inefficient converter, I DON'T see where anyone in this thread but you has made this statement.
The statement I made was...
"with an inefficient converter you can gain some descent 1/4 mile MPH by locking the converter at the proper time."
However, I didn't say that if you need a lockup switch then your converter is necessarily inefficient. Joel, did you assume that's what I meant?
Mike, yes, the lockup is controlled by the PCM so you can lock it through the PCM or you can rig up a lockup switch...the directions for which I don't have handy.
i have rarely seen where locking up the convertor lessens (or gains?) ET. it is that mph in the end to look good against MN6 cars. also a good convertor is more efficient that a stock unit. yank builds a tremendous unit. i love mine, esp on the big end of the track.
Yank or PI and I've run them both and LOVE them both mean tee tee in the real world.
Look at the big dogs out there running glides,400,350 and u wont see these converters in the cars.They run COAN,CHANCE,ATI,TRANS KING,MIKES,TRANS SPECIALTIES,etc...
But Steve I agree with u,I read the repsonses incorrectly.My meds must be off bro
Look I LU switch IMO never helps ET but it does help wth MPH,if its that important to u just add the switch like alot of guys have done.
I did it it was worth 1.2MPH
Tootles....
Tootles....
"My meds must be off bro"
Aww, I figured it was just one too many
I'd put a Yank up against any brand out there. There's only so efficient and hard hitting a converter can get. Neil Chance makes a mighty fine converter I understand...pricey though.
LS1Tech Co-Founder
Dave, if you want my 2 cents...
I had a PI3600 for a while and then I switched over to a Yank TP4500.
I picked up 2mph. So did the other four friends who swapped over.
I'm not telling you to get a new converter, but you need to make sure you have a handle on how this stuff works.
In the old days, folks would manually lock up their converters (GNs) and pick up like 2-3mph. So we tried that with our PI's... I picked up 2mph every time.
Now, you can try adjusting the lockup point in your programming, I want to say that it should be locking up somewhere over 90mph at WOT. If your converter never locks up during a pass you might see like 500-800 rpms of slippage and your mph will suffer. Ever seen 1100 rpms of slippage? I did, I could not hang with a hopped up DSM from a 125mph roll.
Work with your shop to figure out what part of the setup needs tweaking.
You haven't really posted any other detail, so I am just making some very general observations.
