LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Automatic Transmission (https://ls1tech.com/forums/automatic-transmission-13/)
-   -   SS4000....Is it too big for 2.73's???? (https://ls1tech.com/forums/automatic-transmission/116980-ss4000-too-big-2-73s.html)
johnboy Nov 25, 2003 05:20 PM
Basically what the subject says. I have figured out that I have 2.73's. I really want the Yank SS4000 but I am thinking maybe i'll have to do a gear swap also. Can't afford both now so what do you guys think??
WILWAXU Nov 25, 2003 06:27 PM
It will be loose! But, you should get a converter first.
I know we have a few diehard 2.73 guys running larger stalls...hopefully they'll chime in.
Ragtop 99 Nov 25, 2003 08:37 PM
The SS3800 would be a good choice. It will provide a HUGE gain over the stock unit with 2.73s.
The 3600 works well if looseness is a bigger concern.
Plum Crazy Rob Nov 26, 2003 03:51 PM
Yes, it will be loose. If you think you will do a gear later, go for it now though. Needless to say if you drive on the highway with it locked up, its not a prob.
The reason *I* still have 2.73 gears is I'm not spending a f'n dime on this
2 cent 7.5" rearend, but it has not broke after hundreds and hundreds of passes... :judge: :jest: :chug:
onebadz Nov 27, 2003 12:39 PM
Defiantly gonna be loose but I think it would be ok and a very large improvement over the stock converter. Good Luck man
WeS
jruss Nov 27, 2003 01:32 PM
i have the ss3800 with stock 3:23's and I love it!
C54U2NV Nov 27, 2003 04:03 PM
I would go with a vig.3600 .I have had a 3200 for just over a year and have not had any problems.
johnboy Nov 27, 2003 05:41 PM
Thanks C54U2NV, i am looking into the vig. 3600. I have a buddy who has the vig. 3200 in his vette and it seems to be pretty slow :barf: ...... so i am gonna go with a little bit bigger one. thanks for all your help guys
WILWAXU Nov 27, 2003 07:24 PM
Vig 3600? LOL.. that stalls to ~4300 and has a lower STR (you want more with those gears)
It will be looser than the Yank 4000.
johnboy Nov 27, 2003 10:07 PM
:huh: Everyone I have talked to said that PI converters stalled up about 400 more rpms than advertised. That would make the 3600 ~ 4000. Have I been misinformed??
johnboy Nov 27, 2003 10:09 PM
Isnt the price difference between the Yank and the Vig. quite a bit??
Ragtop 99 Nov 28, 2003 09:10 AM
In the LS1 world, the Vig converters stall higher than advertised.
2002 Trans Am Nov 30, 2003 06:25 PM
How much of a differance would it be between a 3600 and 3800 stall for 2.73 gears?
I don't think it would be much, because it is only 200 rpms, but the STR is .05 higher so I assume it should be almost exactly the same
onebadz Nov 30, 2003 09:03 PM
Not much at all, you were right in looking at the STR, that will determine the looseness of the converter. Should be about the same. Good Luck
WeS
johnboy Nov 30, 2003 11:35 PM
If I plan on running nitrous do i need the balloon plate, or does it matter that much?? I know the Vig. comes with it. Would the vig. 3200 or the 3600 be best for my application.
onebadz Dec 1, 2003 08:42 AM
The balloon plate will offer a little extra added security bun not completly necessary. Good Luck man
WeS
Ragtop 99 Dec 1, 2003 08:51 AM
I believe the SS3600 uses a different pump compared to the SS3800. If the pumps are different, the 3600 will be tighter and not have as big a shift extension. Either converter will make a big difference in performance.
The STR is one factor in how loose a converter feels. For example, the YTP series have pretty high STRs but are very loose feeling because of their design that gives them a long shift extension.
Colonel Dec 1, 2003 04:31 PM
I think I'd go with an SS3800 for 2.73 gears in a daily driven car.
The Vig 3600 stalls to about 4300 and would be some kind of MAJOR loose with 2.73 gears. No freakin' way would I drive that converter everyday with those gears.
STR does have some effect on drivability although the stall speed has more.
© 2026 MH Sub I, LLC dba Internet Brands
