diffs. in V/B's for 4l80e i have a spare 2004 4L80E i want to build as a spare over the winter, but robbed the v/b out of it to put in my current 2004 trans i built (switched from full manuel to auto, installed the HD-2 kit) i need another v/b for the other trans, but most of the ones i find are for pre 2004, something changed, not sure what, and wonder how you tell its a 2004 up, so i dont get the wrong one, if i can find one-thanks if i had to, i could switch out the v/b's, but rather have a whole one ready to go, if needed |
Any valve body from a 97 and later unit will work. The only change is the epc solenoid. Vince Bielanski |
i hate to sound stupid, but im used to it, even though i built my own trans, what is the epc sol.?-is it called something else? my repair man. doesnt list anything with that name, but my parts book shows a repair sol. for it i thought 2003 back have a diff. temp sensor, the 2004 uses it in the wiring harness, but thought you could block the early sensor hole and use the later harness i replaced all the sols. and wiring in the trans i built, 4 i believe, 2 shifter and TCC and force mtr, just didnt see anything epc, unless its the pressure switch thanks |
whoops, never mind, found out its the force motor, funny the book never referred it as EPC |
| All times are GMT -5. The time now is 04:20 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
