can a 96 a4 go into a 94 a4 with no problems?
any help would be great, I need to know what will make it work if it wont. Will all electronics, speedo and pcm connection to trans all work correct?
thanks,Tom
thanks,Tom
LS1Tech Sponsor
You will need to make a mod to eliminate PWM to the valve body and you will need to swap the 3-2 solenoid. There is a difference in the 3-2 strategy but i have seen this done and driven the cars afterward and there were no noticable ill effects or long term
__________________
