800 rpm slippage thru convertor at redline
1999 firhawk
T76 turbo
circle D 3200 stall
3.73's
I was doing some datalogging today and comparing engine rpm/ mph/ tire size/
2nd gear pull to redline showed convertor slippage of approx 800rpm @ redline is this normal? This was a pull to redline and let off.
Would the percentage of slippage decrease in 3rd and 4th if I continued accelerating in a 1/4 mile drag type run?
T76 turbo
circle D 3200 stall
3.73's
I thought that too but I'm questioning if maybe there would be less slippage on the top of 3rd and 4th since the rate of acceleration would be less? I don't know, torque convertors are like black magic to me.
"All Motor 9 Second club member"
If you are data logging using HPT or EFI live, you need to log transmission input speed and engine rpms. You can import that data log to an excel file and calculate the efficiency throughout the run. If you don't have much gear in the rear you may be at a lower rpm in 3rd gear and seeing the most slip possible. Most measure the efficiency at the top of 2nd gear unless your gearing is optimum and at redline going through the finish line. I hope this makes sence.
If that is a 2 or 3C it is a very efficient converter.
