98 Pontiac Trans Am Finish Line 4L60E Tranny issue
Moderator
Just to confirm:
You have checked continuity from the VSS to pins 20 and 21 of the red PCM connector?
The VSS was replaced and you even see a signal on the multimeter when the driveshaft turns?
Your speedometer still reads 0 mph?
Have you confirmed that the VSS wires not only have continuity but also are not grounded?
If all those are true, then that just leaves the PCM. Rare but possible.
BTW - My engine and trans are out or I would check what signal I get from the VSS.
All is correct minus checking for grounding. How do Idk that?
My buddy's friend said that this happened on his gto and he turned the vss sensor about 90* and it fixed his problem.
Another local ls guy is telling me finishlibe could have put the wrong ring count in the tailshaft?
Moderator
There have been some mentions here about people installing the wrong VSS.
The wrong ring count would give you the wrong speed, not 0 mph.
Since you said that turning the driveshaft gave you a signal on the multimeter, that indicates the ring is there and that the VSS is responding to it.
Certainly you, but also I and others will be curious what this finally turns out to be. Be sure to post when you figure it out; I'm sure you will.
Moderator
Sorry no; I read nearly every Transmission post , but cannot remember the details of every one months later; nor figure out which one it was.
Assuming most auto stores let you return unused items, why not just get another VSS from a different store and try it. If no difference, clean it and return the $25 part as unused; you certainly would not have damaged it with your test.
Why would it be a bad pcm when everything BUT the speedo work? Thing that bugs me most is why isn't the pcm reading mph if the sensor works and the new wires are good?
Moderator
The sensor puts out a tiny signal, just a few milli-volts which means the PCM has high sensitivity on that line. Perhaps static electricity blew it out when the VSS was disconnected. Sure that is far fetched, but you seem to have eliminated all other possibilities.
#33
Pontiacerator
I think so. After my first converter install, my idle would drop very low when coming to a stop, especially with the A/C on. I bumped up idle speed 100rpm, changed some misfire settings, and advanced some spark to compensate.
IIRC, it's the difference in inertia between the stock converter and aftermarket that confuses the PCM and causes this.
