trans remove help v6 camaro So cars on jack stands in the front and ramps in the back. The haynes manual said I should support the rear with a jack before removing the torque arm bolts out the tail of trans. If its on ramps do I still need to do this? I dont want to loose a finger:shiner:. Do I have to remove the cat converter? It also says to support the engine with a jack too what if I dont? thanks for the help. |
© 2024 MH Sub I, LLC dba Internet Brands
