shifts fine except when i mash the gas I have a stock 99 ta. Car shifts fine a little hard but fine. The problem I'm having is when I'm on the highway and stomp on the gas to pass someone motor just revs and it wont drop gears on me. Any ideas. Tranny fluid is good |
No takers huh. Just left work. Can't pass anyone. Car just revs up. Anyone? |
does it rev up fast or? does it tach out? |
How fast are you going when it revs up or whatever? If its not downshifting then it cant rev up much without slipping. Have you tried manually downshifting and stomping it? |
need alot more information from you... |
alright when i step on it it revs up but doesnt tach out. goes up to around 6 and then goes back down. but doesnt ever actually engage in a lower gear. havent tried to take it to its limits. the car has a lot of miles on it A LOT. planning on building a new block while deriving this one in the dirt. so you can see i dont really want to just hold down the gas and see if itll drop down into say second at 6k rpms. or manually drop shift. but if i need to to find out i guess i will. |
i have also been trying to search the forum and have seen that a tune sometimes helps this problem. i am not throwing any codes either |
Sounds like it might be time for a rebuild... Is your tranny fluid burnt? |
I agree. No doesn't seem burnt but as soon as I get a chance I'm gonna change all fluids and filters and are if it helps any. I'm gonna be looking for a block and when I am ready for the swap I want to convert it to m6 |
How many miles do you have? |
Little over 200k. |
alright so i finally rompped on it and figured out if i quickly stomp on the gas it will drop but if i do not put my foot all the way down it will not drop |
Two things. One, TPS faults will mess with shifting. If your matted TPS voltage is over 4.75 you will be in a fault mode even if not long enough for a code to set. However this usually means hard, short shifting, not what you describe. Two, I have seen many force motor tables that have a "blowoff" current value in the 96% column. In these tunes the max line % is capped at 95%. But if somebody thought they were clever and raised that cap limit, you could step in that hole and throw full motor torque against minimum line, and that'd be the kind of fun you're talking about. Most people don't mess with the force motor profiles. t |
Now when I first get in the car and start it put it in reverse and it does kick pretty hard. Then back in drive the same thing. But when it gets to normal temp it doesn't shift as hard. Could this be what you are talking about. 2nd is pretty hard also but no on the highway there is no hard shifting at all
Originally Posted by jimmyblue
(Post 13950664)
My suggestions pertain to your original post. The hard shift at startup is probably just startup airflow making a higher calculated load and line pressure (and higher startup RPM loading up the converter). |
© 2024 MH Sub I, LLC dba Internet Brands
