How streetable? I was wondering how streetable a 3500stall torque converter is. Also whats the difference in locking them and not looking them? I've never driven a stall converted car and am kinda new to the whole subject. Any advice would be helpful, i'm looking to get a stall to go with a cam thats around the same size as a tr224 with a 112lsa |
With 3.23 gears, a 3500 true stall is very streetable and can be a bit loose with 2.73s (but still quite enjoyable). Looseness varies by model and brand. All late model automatics use a lock-up to reduce rpm and improve fuel economy as part of normal driving. Some people lock their converter in 3rd gear at high rpms. With your set-up you should not need to lock-up a quality 3500 stall converter. |
Originally Posted by Ragtop 99 With 3.23 gears, a 3500 true stall is very streetable and can be a bit loose with 2.73s (but still quite enjoyable). Looseness varies by model and brand. All late model automatics use a lock-up to reduce rpm and improve fuel economy as part of normal driving. Some people lock their converter in 3rd gear at high rpms. With your set-up you should not need to lock-up a quality 3500 stall converter. |
Originally Posted by Ragtop 99 With 3.23 gears, a 3500 true stall is very streetable and can be a bit loose with 2.73s (but still quite enjoyable). Looseness varies by model and brand. All late model automatics use a lock-up to reduce rpm and improve fuel economy as part of normal driving. Some people lock their converter in 3rd gear at high rpms. With your set-up you should not need to lock-up a quality 3500 stall converter. Next mod for me is a TCI 3500.. Now what do you mean by "loose". As in tires & traction or as in lot of RPM's to get going kinda loose? Just wondering if i need to buy 3:73's when i go with the TC. Thanks |
Loose means it will feel like you have to give it alot more gas to get it moving on normal driving. That would be the slipping of the converter , And no you do not have to change your rear end gears, a converter will take sometime to get used to but it is a great mod , best for use A4 guys and will compliment your mods. A nice set of drag radials will be needed to get the car to somewhat hookup, but nothing beats blowing the tires away around 25mph :devil: |
Originally Posted by boomcase Loose means it will feel like you have to give it alot more gas to get it moving on normal driving. That would be the slipping of the converter , And no you do not have to change your rear end gears, a converter will take sometime to get used to but it is a great mod , best for use A4 guys and will compliment your mods. A nice set of drag radials will be needed to get the car to somewhat hookup, but nothing beats blowing the tires away around 25mph :devil: |
I got a TCI SSF 3500 w/ 2.5str and couldnt be happier, I raised the idle a bit with my cam and I have 3.23's. It is perfectly streetable. I will be selling it within a week or two, it has less than 2k miles on it if anyone is interested and wants dibs :) |
Originally Posted by BYOFICR I got a TCI SSF 3500 w/ 2.5str and couldnt be happier, I raised the idle a bit with my cam and I have 3.23's. It is perfectly streetable. I will be selling it within a week or two, it has less than 2k miles on it if anyone is interested and wants dibs :) |
stock converter I have heard being anything from 1600-1900 (depends on who you ask). I am getting rid of mine b/c I am putting the car back to stock. |
Originally Posted by BYOFICR stock converter I have heard being anything from 1600-1900 (depends on who you ask). I am getting rid of mine b/c I am putting the car back to stock. |
Yank 3600SS with 3.42's in a full weight car. Best mod I've ever done, still 110% streetable. Should have come this way from the factory! |
I have a Vig 3200 in my 3.23 LT1, it stalls a little bit higher than that, cars 100% streetable. It doesnt want to roll forward much, thats the main ting I had to get used to. |
If you currently have 323 gears I would not change them, gears are only gonna give you maybe a 1/10 to 1 1/2 tenths in the quarter and your gas milage will drop. To me not worth it , if you have 273s then 342s is the ideal street strip gear, great drivabilty and performance. I will be installing a TCI 3800 stall as soon as it gets warmer , Kevin winstead at tci is hooking me up , If you have any questions give him a call, very nice guy and good at what he does. |
well i'm thinking about the ssf3500 now because i've heard so many good things about it, but i'm still not real sure how the hole stall thing works. I've never drove nor riden in a vehicle that had a stall so i odn't know what to expect. So will it always take off at 3500rpms or what? Oh and how easy it to drive around in like parking lots? |
© 2024 MH Sub I, LLC dba Internet Brands
