Help me fix my 4L60E!
Trans is stock, 27k miles. Only mod to the trans is a derale deep sump pan with the cooling tubes and extra capacity.
I have only really ran a couple bottles of spray on the trans, 3 max.
Anyway, from a dead stop the trans does not seem to slip and shifts firmly at wot in all shifts. Lays the car out and all that.
If I run the car from a roll in 2nd, it slips somethin fierce.
If I am in Drive or Overdrive and floor it, at a speed where the trans kicks down into 2nd, it slips terribly bad.
Converter, everything is stock. 3.42 gears in the rear.
I'm about to throw a new set of heads on her that I have laying around- should get me up over 400rwhp n/a so I know I will need a re-tune, etc, so I figure now is the time to fix the trans too, and get a converter.
I want to get a stall, etc. but am wondering if this is possibly and easier fix than I might think so I can take care of it without pulling the trans.
Any ideas what causing this? I have a few of my own, but just want to throw it out there before I start spending money.
Thanks.
*Replace w/ 4L80e
Yes, its excessive but ultimately the trans is garbage for the power and weight that these cars have. Also this is setting up a excellent foundation for future HP and these transmissions are basically TH400 w/ Overdrive.
BUT in light of your current situation you COULD get away with a quality rebuild, but going to a person exp in this particular transmission is tough, I would say consult with some sponsors.
I will say for the milage, that I am suprised the trans is already taking a dump. Has the PCM tune been modified, or any Torque Management been removed?
I have no issues with taking the trans out, but I don't really want to go the route of buying a new unit, since I live in Hawaii and shipping is something else.
What would cause this? worn 2nd gear clutch pack? Why would it only slip at a low rpm in 2nd but not at high rpm like on the 1-2 shift? 1-2 shift is nice, firm, and sideways. I am assuming that the extra torque at low rpm is the cause.
A little help?
Its absolute nonsense that the 4l60e cant take the power you are putting to it. A 4l80e is not needed. Im not against the 4l80e at all...it is a good tranny.
Build a 4L60E right and it will hold up.
Corvette servo...a must
Kevlar 2-4 band...a must
Valve body updates...a must
beast sunshell...a must
good quality proven clutch kit...a must
heavy duty sprag...a must
tranny cooler...a must
....low rpm....low line pressure....lower holding pressure to 2-4 band...
higher rpm....higher line pressure...higher holding pressure to 2-4....
Have a look see at your cooked 2-4 band
Drop the pan to see the dusting of 2-4 band laying in there.
I work @ a trans shop and I had a 408 sbc 3rd gen that i built along with a 700r4 that we built. My boss and i put a transgo shift kit in it the 160$ one. After that i would not do a full trottle upshift in to 3rd gear. The 1-2 was fine.
So I was getting beat @ the track cuz i had 2 lift so it would shift into 3rd lol.
So after pullin the valve body 4 times and one the phone with transgo countless times we could not figure it out.
So i trashed the valvebody and shift kit. Put another vb and a cheap *** b&m plate kit on it and it was fine,Just one of them things. All trannys have there problems and weak points is what im sayn. Your 4l60e will hold up fine built rite no need for a 4l80 for what your goal is. Im not too found of 4l80s lol
For those of you who are saying that my trans should handle the power:
WTF?
Since when do stock 4L60E's handle 500 rwhp?
Since the last dyno, I changed the exhaust (was running a stock intermediate pipe) and installed a cutout- made a huge difference.
I have a set of cylinder heads and a bottle heater I am going to install too, so I plan on picking up another 60+ at the wheels.
So does anyone around here have a 4L60E that sucessfully handles 550rwhp+?
I am going FI with a turbo 400 or 4L80 with 900 RWHP
