7/16" or 1/2" on converter shims? Inside diameter of hole for the shims? http://www.summitracing.com/parts/MEZ-FPS437125/ or http://www.summitracing.com/parts/MEZ-FPS500125/ To lazy to walk out to the garage to measure the converter bolts. |
7/16" is the ones you need. Some good grade 8 shims from the hardware store will work too. |
© 2024 MH Sub I, LLC dba Internet Brands
