4000 stall + 3.42's i just put a fully race built 4l60e and a fuddel 4000hd stall in my car. it need a retune so its kinda hard to tell but do you think the 4000 stall will work good with my 3.42's or should i step it up to some 3.73's. this is my dd so i dont want something to crazy. |
First,a 4000 against the 'resistance' of 3.42s' will/should require a good size tranny fluid cooler. To answer your ?,4000/3.42 is a good combination.Slippage of the stall might be too much to your liking. 3.73s would make the 4000 a little 'tighter',but 3.42s' are stronger than 3.73s'. After you run it for awhile,you'll determine what direction you want to go. BUT,get a cooler in there to avoid destroying the built tranny. |
i the biggest aftermarket cooler i could find on it. i think ill wait till i get it retuned for the bigger stall, i went from a 3200 to a 4000 so it dosnt really shift right but it still drives nice. |
any other thoughts on this |
my SS4000 & 3.42s drives looser than Id like and I considered going to 3.73s but havent made up my mind yet. |
It will be fine IMO. |
Its all personal preference really. Just get a good tune, and put in some time behind the wheel to see how you feel with the setup. Its like the few people that say a 4k+ stall doesnt make a good daily driver, but Ive driven one (with 3.73s) for a few years now, and have only recently stepped it back to an SS3600. |
I have a DD with a YANK SS4000 and 3.23's ! LOVE IT ! |
Should be fine. Learn punctuation. |
Had SS4000 & 3.42's, loved it. I now have a 3500 & 3.42's, don't like it as much. I needed to be more consistent at the drag strip, that's why I changed the converter. Plus this car is my driver & have not had any problems. It's fun to drive. |
I think you will not find tires to hook that up, and I don't think you have the cam to make good use of a 4000RPM stall speed. But that's water over the dam. If you want to tear up your diff for a 9% increase in rear wheel torque that you can't put to the ground except in 3rd & 4th, rock on. I have a lower stall speed and likely a lower STR than you, and it only hooks up halfway through 2nd on street tires or Mickeys. |
Thats what I run and have no problems .....:D |
I just got my SS4000 and I have 373 gear also to install in my ls1.. Everyone is telling me its gonna be a different animal.. |
Originally Posted by skimms98
(Post 15200263)
Originally Posted by 1Bad97WS-6
(Post 15208485)
Originally Posted by jimmyblue
(Post 15207516)
I just purchased a Yank 3600 SS and I have 2.73 gears. Just basic bolt on mods in the sig, but is this going to be an efficiant set up? It is a daily driver and all you guys keep talking about the high gears, but what is it going to be like with the 2.73's. Will i need to upgrade? |
ss4000 Yank with 4.10's.... Not the most efficient on the highway :judge: |
Originally Posted by Camarosteve44
(Post 15237242)
I just purchased a Yank 3600 SS and I have 2.73 gears. Just basic bolt on mods in the sig, but is this going to be an efficiant set up? It is a daily driver and all you guys keep talking about the high gears, but what is it going to be like with the 2.73's. Will i need to upgrade? Now I have the SS4000 and 3.42s. It's a lot easier to drive. Idk what it is, just going through the gears faster and it's no slouch on the low end. I mean the 2.73s weren't a slouch, I beat plenty of people even with 3.42s and 3.73s but it's a lot quicker now imo. Just need new tires now cuz it blows em off so easy. |
(Post 15237242)
| All times are GMT -5. The time now is 09:49 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
