Will a 4l60e of a ...... Fit my 98 T/A?
Depends on the year but yes, except for the fact that it does not have the right tailshaft, meaning you would need to swap yours over because of the torque arm mount.
And honestly, don't expect an answer in 15 mins.
Yes it will work just fine. But let me make one clarification.... The part referred to as a "tailshaft" is actually the part we call the extension housing. The output shaft is commonly referred to as a tailshaft. No biggie, just don't want to have folks coming away confused.
The extension housing is held to the main case with 6 bolts. It does not have any sealant on it. The way it seals to the main body of the case is with a large square cut o-ring. Just make sure that the o-ring is seated fully against the main case when you swap your old tailhousing on and you'll be fine.
g
g
g
g
That's MISTER MODERATOR
Cool. The transmission and torque should bolt right up. Some truck LS engines had slightly longer crankshafts so I'd have a look into that first. The difference is made up in the flexplate.
UMI makes nice chassis and suspension goodies, they fit well and they are good to deal with if there's a problem. Choose what you need then get pricing from the LS1tech sponsors, they help keep this place alive.
http://www.umiperformance.com/catalo...ex&cPath=7_116
Trucks got it first, SUVs got it the following year. The SUVs I remember had a split year where you could get either with the same year designation during the transition.
