4l80e duel feeding the direct drum
Old 08-16-2011, 08:16 AM
hawkls7's Avatar
Default 4l80e duel feeding the direct drum
For high hp applications is it a must to do this mod , and also can it be done ,
With the transgo hd2 kit already installed ?
Old 08-16-2011, 08:32 AM
Cam72aro's Avatar
According to Jake the hd2 kit does it and yes its a must for high hp applications and really any car running a 80e.
Old 08-16-2011, 08:37 AM
Gilbert@Ace Racing's Avatar
I'm curious as to why you would ask this question. Do you have a -2 kit installed in your 80e already... or are you trying to plan an upgrade to your existing 80e?
In the past I have seen guys take a 60e hd-2 kit and just make the valve body / hydraulic mods but not remove the transmission and modify the rotating assembly. That usually is not a very good idea.
g
Old 08-16-2011, 09:00 AM
built408's Avatar
I would dual feed on any 4l80. The HD-2 kit dual feeds the directs for you. Although I prefer doing it internally, and ditching the HD-2 plate. It's just another potential leak to occur, that's easily eliminated.
Old 08-16-2011, 09:04 AM
hawkls7's Avatar
Hi G , I have the transgo hd2 kit installed already in the trans. It been running ,for about 30,000 k. At 1000rwhp . I have stripped the box due to lock up in reverse, and found a broken rear planet set , due to lube issues. I think I have addressed, but locking at the direct frictions they are the worst. I've heard about this mod in the 400s and I hear that they do it for the 4l80e.
I'm only asking for expert advice . In Australia this box is not a common unit.
most hard parts I have to source from Us. Hope this answers your q.
Old 08-16-2011, 10:24 AM
Jake's Performance's Avatar
The HD2 kits are good but you are probably beyond its capabilities.
Old 08-21-2011, 07:39 PM
hawkls7's Avatar
to upgrade from my hd2 transgo (already installed ) do i remove the seal from the direct drum , drill a bleed hole on corner of drum below piston, remove the second ring from the center support , block the return hole on the left of
the centre support feed orifice , and ditch the transgo plate.
Quick Reply: 4l80e duel feeding the direct drum
