LQ9/4L60E trans wiring diagram?
Old 08-24-2011, 05:55 AM
oldgoat69's Avatar
Default LQ9/4L60E trans wiring diagram?
Does anyone have the wiring/pinout diagram for a 2003 4L60E mated to the same year LQ9? I am using a basically stock harness with DBW. The car will drive but starts in 3rd. I can down shift to 2nd. It does not seem to load when pulled into gear indicative of a locked clutch. I get 2 DTC's P0740 and P0785. I started to check voltage at the trans and am not sure what is really what.
Old 08-26-2011, 12:47 PM
tinktoy's Avatar
Default 4L60E Data
oldgoat69:
Go look where you posted question in the conversion forum. I posted the data you need there. Let us hear how you do with resolving this issue...
Good Luck:
Quick Reply: LQ9/4L60E trans wiring diagram?
