What TH400 year or style do I need?
Old 10-11-2011, 06:33 PM
midwestjunk's Avatar
Default What TH400 year or style do I need?
I'm looking to swap my t-56 for a TH400 trans. the plan is to find a used 400 cheap and bring it to my trans shop after I cut the bell housing off and install an ultrabell. then they can build it for the power i'll be making. what year or specific style of TH400 do i need to search for that will work for my camaro? are the bellhousing bolts the same as my t-56? or will i need a special ultrabell to fit an LS1?
Old 10-11-2011, 07:48 PM
Jake's Performance's Avatar
I believe JW makes an LS1 specific Ultrabell now.
I have cases already cut for an Ultrabell using a mill if you want a case or complete unit.
Old 10-13-2011, 07:36 AM
i 'm just looking for a used th400 that i can cut the case myself. we just did one for my buddies malibu. it wasnt that bad. i'm still not sure what year TH400 i'd need to fit my car? id' assume something from an old camaro or chevelle? maybe and early 70's? i'm not sure how to tell them apart if there are differnces.
Old 10-13-2011, 07:53 AM
Gilbert@Ace Racing's Avatar
JW does have LS specific cases Jake. I've installed a couple of them and they are nice.
OP... what sort of power are you anticipating on making? A TH400 can take a punishment in stock trim.
g
Old 10-14-2011, 07:19 AM
currently the car dyno'd 600 @ the wheels. next season i'd like to build the motor for spray. may make 800@ the wheels.
