Damn bell housing Bolts!!! So I got my new Performabuilt transmission and I was pulling the bell housing off my old one to swap it to the new one. I'm using a 3/8 drive Torx Plus 50 bit and after blowing one of my nuts, I finally got one bolt out. On the second bolt I was very careful to keep the drive straight but the transmission slide a little and I stripped the head. :cry: So now I'm guessing my only option is to drill the head off of the stripped bolt. What kind of drill bit would work best for these bolts? I'm guessing they are extremely hard and I don't think my standard drill bits will work since they barely go through sheet metal anymore. Is there a better way to get this out? Next, how the heck do I get the rest of the bolts out? The options I see are to get a torch and heat up the back of the bell housing. I'm also wondering if I get a 1/2 to 3/8 adapter and use either a huge 1/2 breaker bar or my impact. The impact makes me a little nervous though. Thanks. |
Oh man that sucks. Did you drop the trans brace so you could pull the tail of the trans down? Thats how you can get better access to the bolts and you would go in from an angle with a swivel. As for the stripped bolt dude idk just figure it out. That sucks. |
when i know bolts are gonna be tighter than a dicks hatband i knock the shit outta them with a hammer first. as far as the stripped bolt if you can get a sharp chisel and cut a notch in it then use a dull or flat chisel to work it loose. that works every time...about 90% of the time. it might be best to get an adapter and use a 1/2 inch breaker bar. i stay away from impacts with torx bits. just my .02 though. take it for what its worth. |
Originally Posted by senicalj4579
(Post 15523217)
Originally Posted by msydow
(Post 15523219)
".... if I get a 1/2 to 3/8 adapter and use either a huge 1/2 breaker bar or my impact.." yep, get an adapter or a 1/2 " drive drive Torx Plus 50 bit AND A LONG BREAKER BAR Johnny |
Load it up and bring it to me. I'll handle it for ya, no biggie. I'm in Garland bud. g |
I 2nd smacking it with a hammer first, this works very well. Some use heat. I had one that a previous owner had stripped and I had to drill it out. The bolts aren't that hard, normal drill bits will work, but they need to be sharp or new. Once you drill it large enough, the head will fall off and the remainder will turn out by hand once you get the bell off. |
Those are all great ideas... but I've found that a nice 1/2" impact gun on 120psi shop air and a 1/2 to 3/8 drive adapter works in seconds. For the ones I have to get rowdy with I use a rather aggressive approach. I take my air hammer with a sharp bit that will bite the head and walk it out. Only problem with that maneuver is the bell housing funnels the noise right at my head! LOL... g |
Originally Posted by Gilbert@Ace Racing
(Post 15525077)
Those are all great ideas... but I've found that a nice 1/2" impact gun on 120psi shop air and a 1/2 to 3/8 drive adapter works in seconds. For the ones I have to get rowdy with I use a rather aggressive approach. I take my air hammer with a sharp bit that will bite the head and walk it out. Only problem with that maneuver is the bell housing funnels the noise right at my head! LOL... g To buy a replacement bolt, do I need to go to the dealer or is there someplace else that would have these? |
GM/AC Delco part number 24203265 M10x1.5x45 10 OD Torx Plus HD from GM parts layout catalog |
Thanks for every ones help. A bit of advice to anyone removing these bolts, don't go cheap and get the OTC brand Torx plus 50 bit, get the Snap-on version. After drilling the head off the stripped bolt I was able to finally get the bell housing off. When putting it on the new transmission I stripped 2 more bolts on the last torque pattern. I put lock tight on them and they were close enough to the torque spec that I'm not removing them. I'm guessing that the OTC tool is just a little bit looser fitting that it should be. |
© 2024 MH Sub I, LLC dba Internet Brands
