LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Automatic Transmission (https://ls1tech.com/forums/automatic-transmission-13/)
-   -   Car won't shift (https://ls1tech.com/forums/automatic-transmission/1500561-car-wont-shift.html)
Justinktm Jan 1, 2012 03:18 AM
Car won't shift
I don't get it when the car is cold start I can drive it goes into every gear but once it at running temp it won't shift into any of em and when it does finally shift I can floor it and it barely moves what could that be ?
gofasterdammit Jan 1, 2012 12:29 PM
try this
drop the pan to check for metal in the pan. if there is not alot that could clog the filter then you have a hung valve or worn out sealing rings and need a rebuild. a fluid filter might get you by for a little bit but dought it. good luck!
Justinktm Jan 2, 2012 04:38 AM
Well Im getting it built this week so that's going to solve the problem lol then I'm getting another tune
© 2026 MH Sub I, LLC dba Internet Brands
