Weird popping out of gear feel on a 4l60e??
I have a 94 4l60e that ive rebuilt a few times over the years. Ive been driving on this trans for a while with zero issues and ever since yesterday , when i slow down and the trans downshifts to 2nd , when accellerating and it shifts into 3rd, it feels just like a standard trans popping out of gear. Just like neutral. If i manually downshift back down to 2nd and then manually shift to third it goes into gear and shifts fine.
I know that a bad 2-3 shift selenoid can cause a similar issue but not have 3rd all the time...not even after manually shifting..could it be related to the selenoid?
Any ideas on the culprit?
Mako
Mako
I have also noticed it has a slight delay now in the 2-3 and 3-4 manual shift. All gears are solid and no slipping. Still goes into normal shift routine when shifter is in od. until it goes to shift into 3rd. Seems to happen all the time now.
Nobody has had a similar issue?
