Th-400 Speedo?Help
Th-400 Speedo?Help
Car used to be a 6spd now is a Th-400,I picked up a electronic sensor that goes on the back of the tailshaft of the 400.I have to wire this into the 6spd input wire's what does this conn or wires i need to hook into to get this to work?Car is a 2001 camaro.Also how hard is it to put the ring gear on the outputt shaft and what do i need to put it on?Trying to get this done so any feedback will be helpful
Hmmm....let me see. Maybe attatch them to the wires that went to the speed sensor on the six speed? C'mon man, really? Are you that dense? This ain't rocket surgery. CUT OFF THE FACTORY SPEED SENSOR PLUG AND ATTATCH THE NEW PLUG FOR THE TH400 SPEED SENSOR.
Hey genius, did it ever occur to you that it was an intentional combination of "rocket science" and "brain surgery"? You know, to emphasize how simple and obvious the solution to his conundrum is. You must be the OP's slightly slower twin brother.
I can't believe I'm doing this but here is a link:
http://www.urbandictionary.com/defin...cket%20surgery
And the reason I was being condescending towards the OP is because he got a bit of an attitude in his 6th post when somebody didn't come in here and lead him by the hand.
I took the 6spd out 4 yrs ago,I fianlly trying to get the speedo to work so I forgot which plug was the vss.So this is what I was trying to find out.As for your insults there not called for,Im a adult i won't waste my time argueing with a little boy like yourself.
Ha Ha nice
