Car won't accelerate in 4th gear So today I was on the freeway, and I noticed that when I gave my car some gas, the RPM's would go up, but the car wouldn't go any faster. I got off on the next exit, and my car accelerated normally through gears 1-3. But once it shifted into 4th, the RPM's went up, and the car wouldn't really accelerate. Even if I floored it, the engine would rev, but wouldn't really go any faster. Almost as if it was in neutral. What could be causing this? |
If the car holds 3rd gear solid with no slip at WOT, and it slips it's ass off in 4th but shifts a firm 1-2 at WOT.....it won't be the 3/4 clutch or the band. Might be as simple as a seal on the 4th gear servo. I don't know your skill level, but if u cammed that car yourself u can do the servo seal for sure, with the trans in the car and leaving the pan on. |
It's fried |
i would recommend swapping a 7 speed transmission in there. then you will have 6 usable gears, only 7th won't be usable. |
Originally Posted by Lionhearted
(Post 16286209)
| All times are GMT -5. The time now is 01:56 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
