CS2 Sasuke XD | 07-04-2012 01:18 PM | Transmission problem? Bearing? help? long story: I broke my tail shaft housing doing 137 with a bad Torque arm, replaced everything, but the Bearing in the new/used tail shaft housing. Put about 1500 miles on the new TA, LCA, Panhard bar, relocating bracket, set up fine up until now. When I get into high speed or 3rd gear it makes noise and shakes at 65+ or really noticable when 3rd kicks in, (don't know if it's 3rd gear or a bearing) noise is like a whining noise. Dropped it into neutral at 80 mph and noise and shaking went away. off of load. So, now I have to pin point the rpoblem whether it maybe the bearing or 3rd gear is shot. I am leaning towards bearing because the noise and shaking feels like it's right under the center console. Any insight would be nice.
Short story: rebuild kit? bears? whole transmissions? whats the best of online. |
