Know What This Is On 4L60-E? 2 Attachment(s) Does anyone know what this is? It is from a 2003 Tahoe. Is it the neutral safety switch? Has 10 wires on it. One wire comes from PCM pin C1-34 (wht) Transmission Range Switch Signal P. Another wire comes from PCM pin C1-72 (yel) Transmission Range Switch Signal B. Trying to build a stand a lone wiring harness for a project. Motor is 5.3 flex fuel. |
Neutral saftey switch |
Um, it's more than a neutral safey switch. You can do that with 2 wires, on the shifter itself. This I'm sure is related to the drive by wire system. I believe it tells the pcm what gear is manually selected. Ron |
© 2024 MH Sub I, LLC dba Internet Brands
