LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Automatic Transmission (https://ls1tech.com/forums/automatic-transmission-13/)
-   -   60E guru's, ? (https://ls1tech.com/forums/automatic-transmission/1627893-60e-gurus.html)
LS1MCSS Mar 3, 2013 07:22 AM
60E guru's, ?
I have an 03 4L60E that has 1st, 2nd, and reverse. No 3rd or OD. Any idea what might have gone wrong? It belongs to my son and I'm not sure if made any noise when/before it started this or not.
mrvedit Mar 3, 2013 08:20 AM
Its the most common problem reported with the 4L60E - the 3/4 clutch is toast.
Based on your short description, the trans will need to be pulled and rebuilt.
Either have your local shop rebuilt it with a minimum 7-friction 4L65E clutch kit, or consider purchasing a performance rebuild from one of the sponsors here (Performabuilt, RPM or FLT).
There are similar threads this week, even today:
https://ls1tech.com/forums/automatic...n-problem.html
https://ls1tech.com/forums/automatic...e-rebuild.html
And a bit older:
https://ls1tech.com/forums/automatic...gear-gone.html
The symptom is that on the 2-3 shift the engine rpm climbs rapidly with little or acceleration of the car. Please confirm that to be sure this is the problem.
performabuilt Mar 3, 2013 11:25 AM
Agreed sounds like the 3-4 clutch set is toast time for a new one or a rebuild.
LS1MCSS Mar 4, 2013 09:04 PM
I'll tear into it in a couple of weeks and let you know what happened to it.
mrvedit Mar 5, 2013 01:16 PM
You might want to subscribe to this very similar current thread:
© 2026 MH Sub I, LLC dba Internet Brands
