93 auto transmission help!!
Old Apr 11, 2013 | 02:13 PM
ManMuchwano93z28's Avatar
Default 93 auto transmission help!!
So last year I went to the track and didn't check the fluid level untill I made a few passes and it was low. it was getting stuck in gears untill you punch it and take it up to like 5000-6000 rpm then it would shift but never did that for over drive.. So I parked it for the winter and a few days ago I was driving it to the gas station and it caught over drive perfectly fine.. So do I just leave it alone or do I rebuild it.. It has a shift kit and a 2800 stall.... Do you guys know y this happened and do you think it's okay to drive..??
Old Apr 11, 2013 | 03:26 PM
72blownvert's Avatar
What do you mean? Does the trans not shift? Does it take off in the wrong gear? Are there any codes? We need a lil more info to help.
Old Apr 11, 2013 | 03:34 PM
The trans shifts fine now but before it would only shift if u step on the gas then let off but it shifts fine now and it takes off in first all the time and idk about the codes cause I have a ob1 and sorry I really don't know alot about transmissions what else would you need to know cause like I said I know nothing about transmissions
Old Apr 12, 2013 | 06:05 AM
lt1-xjs's Avatar
The t/v valve may have stuck while you were at the track, it happens on wot runs. It's under spring pressure and probably popped loose. If it's working now it should be fine.
Old Apr 12, 2013 | 12:51 PM
And I also had low trans fluid cause I didn't feel like checking it. You still think that was the problem just the spring..,?
