LS3 and a 4L60e which Flexplate? Hi guys. I bought an LS3 out of a 2013 Camaro and it has nothing on the back. I have a new built RPM Level VI 4L60e to go on, plus I have a converter. I want to retain my old flexplate on my LS1 so I can sell it complete from front pulleys and accessories to flexplate. Does anyone know what I need to fit the 4L60e to the LS3 and who I can get it all from please? I'm from New Zealand so forgive me for not being more clued up about which vendors do all this. Oh yeah - the motor is going to be turbocharged and will make up to 700rwhp for very short bursts but will mainly sit around 550rwhp max to keep it alive longer. That might make a difference in which flexplate and bolts etc. Thanks guys. Love this site :hail: |
LSX SFI NHRA Approved Flexplate |
According to NOS_LS1's link all LS1, LS2 and LS3 take the same flexplate, which is also what I thought. However there are a few (truck?) LS1 "long crank" engines that need a dished flexplate. Correct me if I am wrong. You should read this thread too: https://ls1tech.com/forums/automatic...hes-4004x.html The OP complained that a similar stamped-steel flexplate had enough runout to damage his trans. He went with a TCI machined flexplate that I and other recommended. |
Thanks guys. That was helpful and it's good to know same flexplate fits both LS1 and 3. I'll get one ordered along with quality bolts. |
Originally Posted by Bazman
(Post 17479520)
Thanks guys. That was helpful and it's good to know same flexplate fits both LS1 and 3. I'll get one ordered along with quality bolts. Since a machined flexplate like the TCI is thicker, you need longer flexplate-to-converter bolts; IIRC you need 18mm. Also IIRC, the stock length flexplate-to-crank bolts are long enough for a thicker flexplate. Circle D is a good source for the bolts including ARP; it might be a buck more than Summit, but you will get the right bolts. |
© 2024 MH Sub I, LLC dba Internet Brands
