4l60e Failure/swap metal shavings etc
Old 02-13-2014, 02:26 PM
foot_traffic's Avatar
Default 4l60e Failure/swap metal shavings etc
4l60e Failure/swap metal shavings etc-imag1360.jpgI have two 4l60e's, I was planning on swapping one for the other. The input shaft is very different, as is the output shaft, so for simplicity I thought I'd just swap the bad parts from one to the other, (the oil pump??). When I took the oil pan out, I found this (if the image doesn't load, its sludge, silver sludge and metal shavings that are up to 1-2mm in size. What type of failure would cause this significant of shavings? Is there likely a single part of this trans worth reusing? Can I reassemble the trans that works with the broken trans input shaft?
Old 02-22-2014, 10:24 PM
bbond105's Avatar
What is broken on the trans that fits your car?
Quick Reply: 4l60e Failure/swap metal shavings etc
