1998 T/A trans swap with 3.8 4l60e
Hello everyone, first off, I have done extensive searching on the topic, but have not completely found a definitive answer. These is a lot of conflicting information floating around.
What I have:
1998 Firebird Trans am with a bad 4l60e
What I am trying to find out:
Will a 4l60e trans from a 1998 firebird 3.8v6 fit.
I know I need to change the bellhousing. This leaves the only other issue of the torque converter and the input shaft.
I know about the three different types of input shafts that came with the 4l60e transmissions. The 300mm fully splined "LS1" style, the 298mm piloted lt1/gen1/2 style and a 245mm 2.8 3.4 v6 style. The guy who is selling the transmsion sent me a picture of the input shaft. It is definitely not the 298mm style. I am having a hard time deciphering whether it is the 245mm or 300mm input shaft. I have read many people saying the V6 trans has a different input shaft, but also many who say in the 98+ (different from 97 and older) the trans comes with the 300mm input shaft. If anyone can help by the picture or just by knowing I would appreciate it. I am trying to get the seller to count the splines, because if my research is correct, 300mm=30 spline 245mm=27 splines. I cant say which one is in the picture for certain.
Any help would be greatly appreciated. He is asking $50 for the trans. it is out of a wrecked 45k mile car.
Thanks,
Rob
What I have:
Thanks,
Rob
Moderator
