Trans wont shift from 2nd-3rd under full throttle. I just finished my swap in my 79 Malibu and got it tuned. The transmission shifts fine under normal driving, but under wide open throttle it will not shift from 2nd to 3rd. Any ideas guys? Thanks in advance. Tim. |
If I you want a good answer you have to give more info. What trans for starters? Fluid level good, shifter adjusted properly? |
Plus is it tuned for the trans? Whats the command 2/3 shift, and whats your rev limiter set at? |
"Jake's Performance If I you want a good answer you have to give more info. What trans for starters? Fluid level good, shifter adjusted properly?" Sorry the trans. is a 4L60E, fluid level is good and shifter shifts properly when manually shifting through the gears. "01ssreda4 Plus is it tuned for the trans? What's the command 2/3 shift, and what's your rev limiter set at?" I had the tuner check to make sure that the tune is set up for the 4L60E (old combo had a 4L80E so that was my first thought) but he said he set up right. He said the computer is giving it the command to shift but it will not. Almost like the solenoid is not switching, but it operates perfect during normal driving. Rev. limiter is set at 6800 rpm. Thanks guys. |
I realize its being commanded to shift....but WHEN. Like at what rpm? Its critical that mph requirement is met first, and the rpm commanded has enough time before clipping the limiter. Even with a healthy 4l60e you may see delays of 3/400 rpms between when you ask for a shift and when it actually completes. You MUST compensate for this in the tune. 1/2 seems more dead on with only a slight delay of maybe 50-100rpm, and the hotter the trans fluid the quicker it can shift. As an example, I would command 2/3 at 6150 and it would complete between 6400-6500 with a redline of 6750. This is a comfortable room for error IMO. |
Originally Posted by 01ssreda4
(Post 18517550)
Back to the mph first, I command mph that is the equivalent of say 5900 rpms (since I know I'm commanding around 6100 rpms), so if I'm at 62mph at 5900, then I set wot shift to 62mph, 6150rpm, and shift completes between 64-6500. This way it clips mph first then rpm. Also, there are multiple places to input your wot shifting, and they all need to match. |
(Post 18519145)
Back to the mph first, I command mph that is the equivalent of say 5900 rpms (since I know I'm commanding around 6100 rpms), so if I'm at 62mph at 5900, then I set wot shift to 62mph, 6150rpm, and shift completes between 64-6500. This way it clips mph first then rpm. Also, there are multiple places to input your wot shifting, and they all need to match. Also make sure the WOT shift-MPH is duplicated for the 100% throttle value in the partial-throttle shift table. This way the trans will shift at the tuned RPM (+ or -) and you don't have to worry about the exact MPH. |
© 2024 MH Sub I, LLC dba Internet Brands
