FMVB 4L65e, shifts 1-2-1-2 instead of 1-2-3-4
I recently did an A4 auto swap with a built FMVB 4L65e, no electronics, vacuum modulated. In the vehicle it came from, the transmission worked fine. After the swap, all seemed to work fine for a while, basicly 2 days, but then I started to loose 4th then 3rd, or I thought. While reverse, 1st and 2nd function as normal, once shifted into 3rd it seems to free rev. I assumed the 3-4 clutch issue, but once it slows down, you realize you are back in 1st on the 3rd gear selection, and is functioning as 1st would normally. Once you shift to 4th, it then shifts into 2nd again, and functions as 2nd would normally. WTF?
I can't figure this one out. I've removed, inspected and cleaned the VB. I did find a broken Transgo "White" spring for the 3-4 valve on the FMVB kit, and it was replaced, but the transmission continues to function in this way. Fluid does not smell burned at all, and there was nothing but a small, very slight amount of gold particulate in the pan. What I would consider normal wear.
Anyone have any clue as to what may be my issue? This has me completely baffled. The only change from his car to mine was a Circle D 5C converter.
Jason
Jason
I don’t have any experience with a 4L65E FMVB. I understand it doesn’t shift via a PCM but do you have to manually shift it for every gear change or can you just put it in drive and it will shift on its own? From your description, it sounds like it shifts to 3rd gear but the 3-4 clutches are not holding. The higher stall and horse power may have done the 3-4 clutches in.
You work on manual valvebody A4's? Or want to?
Here is the transmission. Also has rear fluid feed.
Moderator
If you want to try the rebuild yourself, here is a thread in which I gave advice on books, tools, etc:
https://ls1tech.com/forums/automatic...questions.html
Threads on rebuild Kits:
https://ls1tech.com/forums/automatic...-kit-help.html
https://ls1tech.com/forums/automatic...-problems.html
https://ls1tech.com/forums/automatic...-rite-kit.html
https://ls1tech.com/forums/automatic...ild-4l60e.html #5
