4L60e inspection cover removal????????????
Old 12-19-2014, 05:16 AM
ironmikektm525's Avatar
Default 4L60e inspection cover removal????????????
Have to check my converter bolts/flex plate. Can someone plz post a pic of what bolts/locations to remove . basically how do I get cover off. 99 t/a. Thx
Old 12-19-2014, 11:24 AM
bbond105's Avatar
The only way to check the converter/flex plate bolts on an LS1 fbody is to remove the starter and work through the hole where the starter was.
Old 12-19-2014, 06:27 PM
Dang that stinks. Thought I read you could do it by removing some inspection plate? No wonder why when I went under there I didn't see how to anything. Is there enough room to tighten converter bolts if loose through starter hole? I also need to check for cracks on flex plate( I have flexible stick camera). I'm getting a rattle coming from that area between 1.5-2k rpm.sounds like a lifter tick. There's a thin blk plastic piece that appears to be in between tranny and block. When I flick that plastic piece it seems to make that same rattle noise. Hard to tell for sure though. The noise only happens when I'm driving . wont do it in neutral / park . tried power braking it but tires start to turn over before it gets to that rpm .can't duplicate sound any other way. If i manually shift it makes same rattle noise in every gear inbetween same rpm. Oil pressure is good . no change in performance. Any ideas????? Full Bolton's/132k well kept miles. Thx
Old 12-19-2014, 06:32 PM
98CayenneT/A's Avatar
Originally Posted by ironmikektm525
Dang that stinks. Thought I read you could do it by removing some inspection plate? No wonder when I went under there I didn't see how to remove it. Is there enough room to tighten converter bolts of loose through starter hole? I also need to check for cracks on flex plate. I have flexible stick camera to inspect . let me know thx
Yes, pull the starter out of there then turn the flex plate with a screw driver by the teeth carefully till you get to your first converter bolt, there will be 3 bolts
Old 12-19-2014, 06:36 PM
Or put a socket on the under drive pulley and turn it that way to get from bolt to bolt
Old 12-19-2014, 06:57 PM
Cool. What's your thoughts on the symptoms I'm getting?
Old 12-19-2014, 07:21 PM
Stock converter and flex plate ?
Old 12-19-2014, 07:29 PM
Yes both stock
Old 12-19-2014, 07:33 PM
Hard to say without hearing it but I would lean more towards plastic, exhaust or heat shield rattle of some sort
Old 12-19-2014, 07:34 PM
Any shutter or chatter during the rattle rpm range ?
Old 12-19-2014, 07:38 PM
No on both
Old 12-19-2014, 08:01 PM
I guess I would start by making sure everything is tight. That plastic piece by the starter.....keep that from moving around, check exhaust, if you have cats on it still give those a wack.
If all that is good pull the starter down and push on the flex plate, make sure it does not wiggle, if it does the flex plate to crank bolts are loose, check flex plate to converter bolt and go from there
Is it more of a light tick or a rattle ?
Quick Reply: 4L60e inspection cover removal????????????
