4l80e Swap (Shifter Install Questions)
Im in the process of collecting all the necessary swap parts for my 4l80e project. I currently have an 02 Trans Am with a T56.
I am wondering if I can reuse my T56 trans mount on the 4l80e...Or if I need an auto specific mount.
Also, in regards to the drive shaft... I've read that the consensus is that you can reuse the stock drive shaft with just a yoke/Ujoint swap... Is the 4l80e the same length as the T56/4l60e to make this a certainty?
Thanks!
Thanks!
I think the 80 and 60 are close in length but I belive there are 3 different type shafts on the 80. Stock driveshaft length is what I hear works also. Bmr has the mount, but not 100% sure if it's the same with a T56 to 4l80
On a side note... I'm swapping from a T56 and will be installing the factory auto shifter. I am wondering how you guys bolted the factory shifter in place... Did you use self tapping screws? Trying to figure out what screws/bolts ill need to get that thing secure...
