Oreilly brand Trailblazer stall. What do you think?
Glad that you are happy with the new converter. Of course the comparison is a bit flawed because you also upgraded from 5.3l to 6.0l engine which will have much more low end torque.
Unless you are at very high altitude, there is a lot of room for improvement. You used the stock 5.3 cam in your 6.0 engine ??? A moderate aftermarket cam, say something with 0* overlap at 0.050 should give you another 50-75HP and make 11.99 @117 possible. Your current cam probably has negative 22* overlap.
Moderator
Yep Ill probably do some shocks, the budget ZO6 rotor/CTS-V Caliper upgrade, and then some subframe connectors. Then after that maybe ill work on adding more power.
Thats what I heard. I thought id give it a shot for just over $100, whats the worst that could happen. Helped my launch out a ton, even with all season tires. My buddy has a pair of slicks that I may try to borrow to see what the stall can really do. I had to really manage the gas on the launch with these tires.
Yea i hear ya. I can imagine how much harder my launch could be. But still MUCH harder than the stock stall.
Update
The O'Reilly trailblazer stall is still holding up just fine! taken it to the track countless times and I always beat on it when i drive the car. Great budget converter for anyone who still wants stock like drive ability and a much harder launch.
Just did a Transgo HD2 shift kit as well. Another great budget mod for the 4L60e that should be on anyone's list in my opinion. Not at all complicated for the average guy either. If you can do an LS cam swap you can do the HD2 kit.
Thanks for all the replies guys!
Update June 2019, I had no issues to report with this converter. Swapped to a T56 in the car. Now my truck has the same Oreilly converter and i daily drive it with no issues to report. It has been installed for a couple years now.
#33
I want to do this for my 2000 4L60e from a Silverado, but I think the input shaft diameter changed at some point.
#34
As long as it's an LS based 2000 4L60E the trailblazer converter will work. I do it all the time. Just doulble check the converter pad to flexplate clearance. 1/8"-3/16" Max. Shim it if its more...
#35
The 5.3L with TSP stage 2 truck cam is going in my Jeep Wrangler. Occasionally, I will pull a 3500 lb trailer. Do you think there would be any issues in a 4x4 / rock crawling or towing application?
#36
No the lockup clutch is smaller.
Only use lockup when cruising under light load.
#37
UPDATE
Got rid of the truck a year or two ago and it was still going strong with the trailblazer converter. Part number GM55 at oreilly. It had a texas speed NSR cam and that converter in a 4.8 and it drove great.
The following 2 users liked this post by SiskMan:
Ls7colorado (04-29-2022), sheza65 (04-29-2022)
#38
for anybody that cares
I decided to try this converter for myself just to see how it would behave
let me tell ya...poopy dog water
it stalls higher...if that's all you care about...it'll be fine
but it drives like *** in a heavy vehicle for daily driving.
Mushy/sloppy/crappy
If you like the feeling of driving a golf cart...this is the converter for you
If you just want the absolute cheapest thing that will work with a larger duration camshaft...this is the converter for you
I kept having customers ask and ask about it and decided I'd just try one and after a few months of daily driver duty...I hate it and it'll be coming out for a nice unit.
But...to the OP's point...it is cheap. and it does work. and it didn't die.
Mushy/sloppy/crappy
#39
I used this torque converter too. It is in a 5,000 lb Jeep Wrangler on 35" tires with 5.3L and BTR stage 2 truck cam. It works really well. It has noticeably higher stall RPM, but not too much, and gets the engine into its its power much better. My converter isn't sloppy or mushy.
#40
Don't mean to be rude
have you ever driven something with a properly spec'd converter with the right diameter and stator?
You'd get the same stall, with much better driving characteristics, and would be faster as well
If you're happy with it great, but for someone wanting this in a TBSS, or a silverado/sierra, etc...especially with factory rear gear ratio...it's gonna feel like poopy
either that or I'm picky and other people just don't seem to care/notice the nuances of how a converter should behave
The following users liked this post:
bbond105 (04-29-2022)
