2.75 turbo 400 gearset, snap ring prob. - LS1TECH - Camaro and Firebird Forum Discussion
Automatic Transmission 4L60E | 4L80E | TH350 | TH400 | TH2004R | Powerglide | Converters | Shift Kits
Thread Tools Search this Thread
Old 01-02-2016, 02:09 PM   #1
forcd ind's Avatar
Default 2.75 turbo 400 gearset, snap ring prob.
I have a 2.75 gear set, I think they were Kilgores, that I am putting in my 400
When I try and install the output shaft into the output carrier, there isn't enough space for the snap ring-I cant use any thinner bearing under the rear internal gear because it almost touching the output carrier
Do they make a thinner snap ring?
forcd ind is offline   Reply With Quote
Old 01-02-2016, 07:41 PM   #2
Jays_SSZ28's Avatar
Did you try to eliminate all other things and just install the output shaft into the output carrier with nothing inside?
Jays_SSZ28 is offline   Reply With Quote
Old 01-03-2016, 10:45 AM   #3
forcd ind's Avatar
I think I see the problem, the snap ring slot is further down than the orig one
In the pic the "teeth" for a better word above the snap ring grove are thicker
There may well be a thinner snap ring that is supposed to go with this setup
Related Topics
Thread Thread Starter Forum Replies Last Post
390 gear kit: price dropped! LQZ Parts Classifieds 4 08-11-2017 07:25 PM
Th400 snap rings Game ova Automatic Transmission 3 01-17-2017 01:33 PM
Piston ring issues? Bulletin? Batass Generation V Internal Engine 6 05-19-2016 03:05 AM
4l80e output carrier chipped fzj80lq4 Automatic Transmission 2 04-02-2016 11:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
