What should I do? 4l80e swap wires 60e or 80e segment
Found a bunch of old threads but figured I'd ask. I swapped 60e to 80e. I have a Nelson performance main plug adapter. I do not have iss wire but can make one I'm sure. But I see some older threads saying just use the 60e tune. Is there any update that makes 80e segment better now? Also if using the 60e file and switching the wires around on the main plug i just switch them around on my adapter plug? Or factory plug?
if you use the adapter you will not switch wires around
if you do not use the adapter you will
either of those options will require adding a second VSS and a 4l80e segment swap in the pcm
there is a way to avoid the segment swap that involves some rewiring and adding some relays, a search will find it. I have never done that.
It mostly boils down to if there is a segment available for your pcm
