How much power can a 4l80 survive under?
With every bell and whistle how much can these transmissions really hold? I keep having problems with mine in the 1000-1200 hp range and I'm looking to turn it up more? What can be done to bulletproof these things? Or is it glide time?
Yeah at your power level it's probably more critical then mine.
How are you doing your burnouts?
I think if you leave it in D3 you "should" be ok.
At least that's what I've read.
Yeah, that can't be good for it.
I think as long as your in D3 or lower, you have extra clutches engaged to help support the sprag.
I'm sure a guru will correct me if I'm wrong.
I do my burnouts in 2nd and shift to 3rd just as I release the front brake. I don't have 1000hp though.
When you put it in 2nd, does it start in 2nd or go 1st to to 2nd then you shift to 3rd?
I can put my controller in manual mode and it will start in any gear that its put in.
I really want to know the correct way to do the burnout.
