Converter I'd help! 4 Attachment(s) I was told this converter fits an LS fbody 4L60e but I'm not sure. See pics & please let me know... Thanks! |
who makes it? You cant really say unless you can contact the manufacture or do some measuring. |
That's the thing... I was hoping someone could ID the numbers on it. I haven't had any luck so far. I can certainly measure it every way possible. What dimensions am I looking for? |
Not sure on the make but it looks to be built for an LS from what I see. Looks like a decent bit of pump wear on the hub though, are there deep marks around that area? |
Thanks for the reply. No abnormal wear from what I can see and feel. I was told it was a 3600 but just want to find some info before trying it in my 01 Formula. |
Edge Racing |
Originally Posted by Nobody.
(Post 19643281)
Thanks for the reply. No abnormal wear from what I can see and feel. I was told it was a 3600 but just want to find some info before trying it in my 01 Formula. These types of converters have fairly small lock-up clutches as well, make sure you disable any PWM if you have it. |
The car is basically stock with 3.42 gears. I plan to cam it soon hince the need for the converter change. The Trans was recently rebuilt before I bought the car & it shifts really firm on each gear but no idea about disabling the PWM. How to check? |
(Post 19643976)
| All times are GMT -5. The time now is 02:47 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
