4l60e check ball question
When I pulled the valve body apart I found another cb that is probably close to half the size of the others and I'm not sure where this came from or what it may have been for...
Is it an issue or problem that the one in the case by the accumulator isn't there?
Is this smaller ball made of steel?
The builder may have installed a smaller check ball in the case (4th Accumulator) by accident.
The "Captured" ball in the case can cause issues if it blows out & gets hung-up in the L/R clutch.
The 4th Accumulator check ball has never given any issues, All it does is meter Accumulator Oil to keep the piston from slamming against the case.
If your speaking about the 3-4 under the servo plate it has a pinned piston in it but I found that the passage at the bottom of the bore blocked by a CB so it apears that the 3-4 accumulator is now rendered useless...
The l/r has no checkball in it so it was either removed prior or this is the CB I found in the vb if it fell out....
I aquired another CB to replace the missing one in the case when I put everything back together...( wasn't a bad deal finally the CB, 1-2 accumulator housing,metal piston/pin and correct spring for 5 bucks at a trans shop) so I can at least have that function as it should hopefully
The 3rd accumulator captured check ball is bigger than 1/4"....It didn't come from there.
The "free/non-captured" check ball in the case...Above the separator plate is the 4th accumulator check ball. If the 4th accumulator piston is pinned/shimmed to where it doesn't move....The check ball is useless/non functional & the builder may have left it out.
Blocking the piston up or down in it's bore effectively blocks the 4th accumulator from functioning.....So why block the 4th clutch feed in the case & cut lube to the L/R frictions? Make no since to do both.
IIRC the captured ball in the case is also a 1/4" ball so I don't think your errant check ball is from that location.
