Th400 billet shaft/drum...sub 1krwhp?
Couple weeks ago I had rear end yoke let go during a hard launch at the track, so I'm going to take a look at the transmission here soon. While I'm in it, going to go ahead and do a 4 clutch intermediate as I think I'm exceeding it's holding capacity. Now, as far as the input/forward drum....on a car that makes 745/1045, would I high end billet setup be like putting wheelie bars on a prius...as in completely unnecessary? I guess one could say just do it since you're already in the transmission, but they piece I'm looking at is over $600....not exactly cheap. Basically, I don't want to be buying high end pieces if the stocker is more than adequate.
I would upgrade, But not with a $600 dollar shaft & drum, Eliminating the under cut's in the shaft alone does quite a bit in the strength department. I think this would be a good match for what your doing at half the price......http://www.ckperformance.com/View/CO...SHAFT-AND-DRUM
For your power level the stock hard parts are going to be fine.
If the car leaves super hard and is heavy, ya the input and forward hub could be replaced.
but lots of guys run bottom 9s with the stock parts in f bodies. or faster if the cars light
It definitely leaves hard and is heavy. I think I'm going to do the input shaft/forward drum.....but stay with the stock intermediate shaft. Having Already done the 4L80 direct, and after this forward drum upgrade (barring anymore driveline failures) I hope to run this transmission for many years to come.
After breaking a stock unit I waited for FTI's black Friday sale and got their Level 4.5 for a good deal and never had another issue despite doubling the horsepower. Their build consists of the following rated to 1100HP:
-Race prepped factory Chevy case
-FTI Billet aluminum transbrake valvebody
-Reverse shift pattern
-Billet aluminum drum
-34 element sprague
-300M Material input shaft
-BIllet forward clutch hub
-Race material clutches
-Deep aluminum pan
LS1Tech Sponsor
I managed to break a TH400 NA... so power alone isn't always the defining factor.
-34 element sprague
-Deep aluminum pan
-34 element sprague
-Deep aluminum pan
Here's a link to that input drum with the option to upgrade to our ERMET input shaft and drum that's rated to 2000HP!
http://ftiperformance.com/TH400-Inpu...?categoryId=-1
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
Nice! That 300M input shaft(1100HP rated) is also oversized at the drum as you guys mentioned above.
LS1Tech Sponsor
Yessir, all of our ratings are at the crank!
__________________
1-866-726-8358
FTIPerformance.com
1-866-726-8358
FTIPerformance.com
