Factory transmission angle
Old Sep 25, 2017 | 08:11 PM
fastlt1's Avatar
Default Factory transmission angle
If someone can measure the angle of the factory 4l60e and compare it to something on the body would be great. I believe when I did my transmission swap it is pointing down in the rear. It has my exhaust and everything hanging low.
Old Sep 26, 2017 | 06:35 AM
forcd ind's Avatar
You are lacking a ton of information-you need to ck the angle against the rear end
Old Sep 26, 2017 | 11:41 AM
fastlt1's Avatar
I went from 4l60e to th400 using umi th400 torque arm relocation. I think transmission bushing I'm using is too short and letting exhaust and tail shafts hanging too low
Old Sep 26, 2017 | 05:49 PM
fastlt1's Avatar
This is what I am talking about
fastlt1's Avatar
