5.3 W/4l80e swap....higher cruise TPS%
just did a 4l80e swap on my turbo 5.3 car. shifts into od at 55..then lock up at 57. ...car use to cruise at 10% TPS now its 18+ and 12 vacuum... just to keep it at a steady cruise. 3.23 rear gears...prob are not helping . anyone else have this issue
That's weird. Especially a car with a turbo you would think it would take less throttle.
My gearing is much steeper and I have to fight it not to speed with 5% throttle in a 50mph zone.
Mine is programmed to lock at 47 and unlock at 30% throttle.
I think "maybe" have to step up rear ratio OR check for TCC slip in 4th.
I went from a 350 also ...but doesn't feel any different in the 1st 3 gears as the are .004 less then the 350.
OD and lock up is awesome as I didn't have it before and can run rt 80 at 80 now if I want instead of being in the slow lane.
Not necessarily, A lot depends the camshaft, Some just aren't efficient at low rpm and some work fine.
You can't go just by Throttle position and vacuum, Keep in mind that you are now traveling further for with every crankshaft revolution than you were with the none OD transmission. Changing gear will bring the rpms/vacuum back up but your still traveling a shorter distance.
In the end your still pushing nearly the same weight with the same engine although you should see a slight increase in economy with OD.
As I and LLLosngit said it's just a more inefficient rpm for the motor. I don't believe putting a higher gear in is the answer for you either. Being turbo I'm sure you really like the way them longer gears pull once boost really starts kicking in. Your probly better off just taking advantage off the lock up in 3rd while at 65 and under and only using od when cruising 70 or above.
The way to compare economy is by comparing injector duty and engine vacuum. You can sometimes neglect the engine vacuum but it helps to factor in for accuracy because vacuum changes the injector flow rate (yes even in non-referenced setups).
The more throttle position typically means fuller cylinder- which means higher injector pulse widths. However the lower RPM means that overall duty cycle could/should be lower, which is what really matters most.
