4L60E Recommended Rebuild Kit (2nd Time Around)
#61
So I have kind of great news. The transmission is back on and the truck is ready to go. I was able to get it to move in reverse with all the new components and it didn't explode on me, so that's a good thing.
I have a problem and I already think I know the answer to it. When I'm moving the lever to shift gears, I noticed that trying to shift back into "Park," the lever moves into its seat very freely but the dashboard doesn't state "Park" and I didn't get the feel of a shift into park. I had to go back to "Neutral" and quickly move it past "Reverse" to get it into "Park." It did this twice, at least both times I tried. Note, this only occurs when trying to shift back into park. So if I go from "Park" down to "Drive," each gear engages fine, it's going from "Neutral" back to "Park" that's the issue.
I think my problem is that I put the shift cable in the wrong orientation with respect to all the wires and hoses running along the transmission and transfer case. Sadly, since I wasted two hours reorienting the hose bracket at the top of the transmission (after putting the transfer case on and realizing the hose didn't reach), I wasn't able to test this theory since it got too dark and too cold to go back under the truck.
My question is, would a new neutral park safety switch have anything to do with this? I replaced it because the plastic for the top connector cracked off when taking it off. I don't know if I need to have this reprogrammed or something, my gut is no since these trucks are very basic for electronics underneath.
#62
It sounds like the shift linkage is a little out of adjustment, not pushing the lever all of the way forward. I like to adjust the linkage with the trans lever in neutral and the shift lever in neutral.
#63
That's a good idea since neutral is in the middle position. I take it that's two clicks over from the locked "Park" position for the parking pawl assembly (the rooster comb looking piece of metal that has the different positions), right?
#64
Alright so readjusting the shift linkage helped a lot. It was getting caught on the vent hoses (transmission/transfer case) going back and forth for each gear. I just placed it above everything and it all checked.
And...
I took her for a test drive and it seems I have done it again. Thirteen miles with no apparent problems (other than the brakes needing to be warmed up). I will need to double check the fluid level, I know I put 9.5 quarts out of the bottles I had left over. I presoaked everything and I put in probably 1/4 to 1/2 a quart in the torque converter to lubricate it up. I think I need less than 1 quart to make it to around 11 and I will be doing that promptly.
Again, thanks for the help guys. I know thirteen miles isn't a lot and I will need to drive it more to be more and more sure, but we'll see what happens after a couple of more miles (or hundreds of more miles).
Now back to those ball joints I was going to replace before all of this...
And...
#68
If you need any suggestions along the way, feel free to ask. I figured out a few tricks in place of some of the tools people will tell you to buy.
