Anyone using Jake's 4L80e Rebuild Kit?
I know this question has been asked before... but wondering how the Jake's Lvl 2 rebuild kit shifts and if everyone is happy with it when they had a local builder build the trans instead of Jakes? I only have experience with a factory 80e with a Transgo in it and that trans shifted awesome at WOT and part throttle 2-3 and 3-4 but the part throttle 1-2 shift was a little bit harsh. I'm wondering what a Jake's kit would feel like? I'll be having my local trans shop do the rebuild on a core I sourced.
It's a very complete kit from the looks of it. To be honest, the only special things you're going to get is the machined forward hub (people call this "rollerized") and the 34 element sprag.
Those mods alone, along with dual feeding the directs of course, will make for a very stout build. In my opinion, it's more money than I'm used to seeing for that list of parts, but Jake needs to make his cut, and he's taken the time to package it all nicely for you so that you don't have to do the resource and source parts by yourself. His knowledge of matching parts is probably worth the price hike. And Jake has shared so much info on forums over the years, I don't think anyone is going to say he deserves any less money.
I think his 750 hp rating on the kit is certainly legit, maybe even a little under rated.
Don't use an HD2 with this kit. You can do everything needed without the HD2.
Short answer, Yes. It's a good kit.
The following users liked this post:
jeremyfrank14 (06-28-2022)
https://ls1tech.com/forums/automatic...build-kit.html
Correct his level 2 kit comes with the sprag and hub. Those are the special parts.
Make sure your builder sets proper clearance in the clutches and gets correct endplay. He can also rollerize the output using a th350 pump bearing.
I'm not sure if Jake's kit comes with it or not, but I would install a sonnax boost valve for the 80e. It provides very good line pressure and line pressure rise. Better than just a stiffer spring in my opinion.
Good luck and enjoy the stout 80e
I do recommend checking the AFL valve for wear. We ream and replace all of them on the valve bodies we build.
Sonnax makes nice stuff.
Jake has given out much of the info in these kits already for free on this forum and others, and many people can preach the success of the valve body mods he recommends.
Thanks for hanging out here on the forums and helping the little guy Jake.
