Oil cooler line plastic fitting caps , what P/N ?
there are 2 plastic pieces on the oil cooler line by the cooler line fittings on the side of the trans ...1 is a cap GM 15052228....the other is a plastic disc that goes against that cap.....any one happen to know the P/N and if its availible ?
*puts on engineer hat* i think the caps keep the cooler fitting clips from flying off....and the discs keep the caps pressed against the fittings and from sliding down the cooler line
i zip tied the discs in place on the line...but then realized i might need high temp zip ties !!!
if anybody is good at part num research and you can find those discs let us know !!!!!!
Engineer LMAO jesus christ.
More like Hi I'm sjsingle and I have OCD too.
In other words you just want the caps and discs so you can sleep at night, I get it. Nothing wrong with that and no offense I am not being serious, but it is kind of true.
If you want the caps you want the caps.
