Dropped the valve body and now vehicle won't move So before I go digging into the transmission again, I wanted to ask a couple questions. I've been driving my Jeep with a 1999 5.3 LS engine and a 2002 4L60E for about 1000 miles. It's mostly been fine but I've been troubleshooting a hard 1-2 shift and tried changing a few things without much luck. Finally gave up and went to change the TCC valve. I tried to do the trick without dropping the valve body but after 2 hours, I gave up and dropped the valve body making a huge mess. I also decided while everything was empty, I'd toss in a trans cooler. So I replaced the TCC valve and filled the transmission and now I have no forward or reverse gears. I added roughly what I took out and got nothing so I continued to add another 3 quarts before I decided that was more than enough and something else is wrong. When I shift into reverse or drive, the engine rpms drop like it normally would but it doesn't move. If I jack up the rear of the vehicle, the rear wheels will spin in every gear except park...including neutral. The really odd thing is they will spin in reverse in all gears one time and then they will spin forward in all gears the next time. I can stop the tires with my hands though. Any idea what I messed up during assembly? |
If you don't have a scan tool, I would drop pan and check that the manual valve link is hooked up. |
Originally Posted by bbond105
(Post 19983897)
I would guess manual valve also |
Originally Posted by jfw432
(Post 19984000)
Yep...the tab that holds the bar onto the manual valve must've broken when I installed it and the link was just hanging there. I appreciate the help. I guess the sucky part is I'll have to order that part and drop the valve body again just to change that stupid thing. Takes a lot to break anything you're talking about. I'd put money on nothing being broken. |
Originally Posted by Jays_SSZ28
(Post 19984007)
Got a picture? Takes a lot to break anything you're talking about. I'd put money on nothing being broken. https://cimg9.ibsrv.net/gimg/ls1tech...31bd53e5d3.jpg https://cimg8.ibsrv.net/gimg/ls1tech...4162f610ce.jpg |
I doubt you broke it. I'd bet you just missed the hole or forgot about it when you went to install it. Takes alot to break anything in the linkage inside the trans. |
I'm not sure why it didn't take yesterday but there is a bit more to this story. I initially broke the tab trying to get it in. To prevent having to wait another week for a new valve, I welded the tab back on since it's really just a retaining tab and shouldn't see any load. I was confident with the weld but I guess it just didn't hold up. The first picture is what it looks like and the second I just connected the link for reference. https://cimg3.ibsrv.net/gimg/ls1tech...99d6a49b37.jpg https://cimg5.ibsrv.net/gimg/ls1tech...7dc4fef086.jpg |
A moderator has to approve my pictures apparently so I can't upload anything. I'll try to describe it as best I can. I initially broke the tab trying to get it in. To prevent having to wait another week for a new valve, I welded the tab back on since it's really just a retaining tab and shouldn't see any load. I was confident with the weld so I didn't mention it but I guess it just didn't hold up and it was the root cause of this problem. I should have my new valve next week. |
I'd really like to see a picture of that. |
It sounds like op broke the little ear off the manual valve that keeps the link from falling out of the hole. |
Well maybe I can show you pictures this way... First one is a closeup and the second I reattached the link just to show it. https://preview.ibb.co/i5drTp/201810...56-resized.jpg https://image.ibb.co/gGq5op/20181011-211008-resized.jpg |
© 2024 MH Sub I, LLC dba Internet Brands
