4L60E neutral safety switch connector using GM p/n connector. What pins do I need .
Using Ls1 and 4l60 E from a 2004 GTO. Trying to figure out which pins need to be hooked up. there is transmission range switches range A,B,C, and P. clutch start switch signal ground, park neutral switch, back up lamp supply voltage, and 2 separate ignition 1 voltages. Any help not only on which switches to use also where to wire them into. Thanks
There are loads of threads on this already. I see this is your first post so...go use the search function. Also read into the LT1swap.com material.
Maroon monster I did spend several hours looking before I posted and several more sine your post. I'm still trying to find out how many wires I need to use and if you know what I'm asking if you could help me.
