P0713 p0740 p1810
P0713 p0740 p1810
i have a 99 z 4l60e fti 3600 converter recently just had the trans rebuilt my trans builder had to use another trans shell from a junkyard now that I have the trans back in the car I am getting those 3 CEL. In drive and od the car feels like it takes off in third and when I drop it to L it feels like it takes off in second not sure if that’s really what’s happening or I am having a issue with torque converter
LS1Tech Sponsor
Well po713 is trans temp sensor circuit high input
P0740 is TCC SOLENOID ELECTRICAL
P1810 - TFP Valve Position Switch Circuit
Best guess is check connector at trans and in harness for damaged pins But would point to an electrical not mechanical issue imo.
__________________
I checked connectors that’s what’s going on they left it out. I plugged in the sensor on the side of trans but I don’t see the speed sensor coming off the harness to plug that in or would the speed sensor wire be coming from a different location
